What is the Dark Web?
- The dark web is a hidden portion of the internet that is not indexed by search engines and requires a specialized browser such as Tor to access.
- Users can remain anonymous on the dark web, which makes it attractive for both legitimate privacy-focused activities and cybercriminal activity.
Deep Web vs. Dark Web
- The deep web includes content not indexed by search engines, such as membership sites, private databases, and paywalled content.
- The dark web is a small, intentionally hidden subset of the deep web that requires special tools to access.
Is the Dark Web Illegal?
- The dark web itself is not illegal.
- However, cybercriminals often use it to buy and sell stolen data, including personal information obtained through breaches or hacks.
Why Criminals Want Your Data
- Personal information has value even if it seems unimportant.
- Stolen credentials, credit card numbers, and other sensitive data can be sold individually or in bulk after data breaches.
Is the Dark Web Dangerous?
- Simply accessing the dark web is not inherently dangerous.
- The primary risk is having your personal information exposed and traded after a breach.
How to Protect Yourself
LastPass recommends:
- Create unique and strong passwords for every online account.
- Store passwords in a password manager like LastPass to help manage and monitor them.
- Enable multi-factor authentication (MFA) wherever available.
- Use a dark web monitoring service to identify compromised credentials quickly.
How LastPass Dark Web Monitoring Works
- LastPass checks users' email addresses against Enzoic's database of known breached credentials.
- If a monitored email address appears in a breach, users receive:
- An email notification
- An in-product alert
- Alerts identify which account may be at risk so users can take action.
Signs Your Email May Have Been Compromised
- Strange messages in your Sent folder.
- Unexpected password reset emails.
- Complaints from contacts about suspicious emails.
- Unrecognized devices, browsers, or IP addresses accessing your account.
What to Do If You Receive a Dark Web Alert
- Immediately change the password for the affected account.
- Review the account for suspicious activity and update any reused passwords elsewhere.
Is Dark Web Monitoring Enough?
- Dark web monitoring is an important security tool, but it is not a complete solution.
- Users should also:
- Avoid password reuse.
- Enable MFA.
- Practice safe browsing habits.
- Consider using a VPN on untrusted networks.
Does LastPass Scan the Entire Dark Web?
- No. The term "dark web scan" generally means credentials are checked against databases of known breached records.
- LastPass uses Enzoic's breach database while maintaining its zero-knowledge security model.
Business Benefits
- Dark web monitoring is available for LastPass business users.
- It helps organizations identify employees whose credentials have been exposed, reducing the risk of account compromise due to weak or reused passwords.
Bottom line: Dark web monitoring helps you discover when your credentials appear in known data breaches, but the most effective protection comes from combining it with strong unique passwords, MFA, a password manager, and good overall cybersecurity habits.
