I'm feeling confused about passkeys.
On one hand, it says that LastPass will store passkeys to be used anywhere:
"LastPass helps you to easily and securely use the same passkey on multiple devices and platforms."
https://support.lastpass.com/s/document-item?language=en_US&bundleId=lastpass&topicId=LastPass/about_passkeys.html&_LANG=enus
Yet here it says that the private key is stored on the device:
"The private key of a passkey is stored directly on your device."
https://support.lastpass.com/s/document-item?bundleId=lastpass&topicId=LastPass/passkey_faqs.html&_LANG=enus
I've tried to create a passkey for Google on my desktop PC running Linux and the Brave browser. I have the LastPass browser extension. All I did was click on "Create Passkey" and LastPass popped up during creation asking to store the passkey, which I accepted. That's all. It was then all successful according to Google even if I didn't have to do anything else. Google mentioned fingerprint, face scan, phone pin, linking my phone, etc but none of it was needed here.
However, when I tested it, it didn't work.
Google doesn't list Brave or Linux as supported browser and OS. At the same time, Google says to wait 7 days for the passkey to work, so why offer a test button?
According to LastPass, the passkey saved there should work on any device and browser where the extension is installed…
Google says I have to generate a passkey for every device I own. LastPass here says the same passkey can be used across devices…
Can someone help me clear all this confusion and get it working on Google?
