Hi there,
Welcome to the LastPass Community.
After reviewing your LastPass account, it appears you recently set this up.
If you are attempting to gain access because you lost the password, then I suggest resetting the login, followed by setting all available recovery options:
If you are attempting to set up multifactor authentication, then the code you received may need to be confirmed before the MFA selection can be applied.
