When I go into Advanced Settings and Disable the Use Improved Save and Fill, it does not stay disabled after I close my browser or reboot my computer. It continually goes back to the apparently default setting of enabled.
I have been disabling the horribly buggy and garbage "Improved Save and Fill" since it first came out a while back. I disable it because it causes FAR MORE problems than it "improves". And although I remember other reports of users having problems with disabling it a year or so ago, I did not have any problems disabling it until very recently.
I'm sure this is yet another example of how LastPass continues to turn its once-great product into a raging dumpster fire of buggy features, security breaches, and product mismanagement. But hopefully someone might be able to give me an insight as to how to actually fix this thing.
I honestly expect the answer to be "Go into advanced settings and disable it" (which I have already done a thousand times, that's the problem) because that is par for the course with LastPass and its bumbling incompetence these days. But I figure it's worth a shot before I bite the bullet and go through the incredible inconvenience of switching to a superior competitor password manager.
