Hello@"User17606144766658222842"
Welcome to the LastPass Community.
Yes — you can absolutely use multi-factor authentication (MFA) for other websites you've saved in your LastPass vault. However, it's important to know that each website has its own way of implementing MFA, which means the process to set it up will vary depending on the site you're working with.
Some websites support authenticator apps like LastPass Authenticator, while others may offer SMS codes, email verification, or even hardware security keys like YubiKey. Because of these differences, there’s no one-size-fits-all method — but don’t worry, I’ll walk you through the most common scenarios so you know exactly what to do.
Here is the link to: Enable multifactor authentication for LastPass
A Simple Guide to Setting Up MFA on Other Sites
Here’s how you can approach enabling MFA for your other saved logins:
1. Check if the website supports MFA
2. Find out what type of MFA the site uses
Most sites offer one or more of the following:
3. Set up the MFA method
4. Test the setup
Greetings!
Luis | Customer Care
