I expose the problem here, since the email support doesn't answer / answer not the designated issue.
I finally got my problem solved, may be thanks to this post.
How may times I have to pay for the service to be activated ?
NO. This is not an answer.
@DarkbunnySorry for the frustration, you should be hearing from someone any time now.
@PAVEL-PETRENKOI have looked at your account and it shows that you had a Family plan trial that has expired, what exactly happens when you try to purchase a paid plan through your account?
Please, figure out what is going on asap.
Same USSUE !
Already 3 days as I paid in full for Family Account and in theory should be able to use family features.
I have access to my account BUT .............
I can't use 2FA by Yubikey.
Sorry but it is NOT SOLVED
Hi@"PAVEL-PETRENKO",
Some of the screenshots that you had previously posted showed your full email address, for your security I have removed those screenshots. I reviewed your LastPass account and see that a YubiKey is enabled for this account, are you able to use the YubiKey or what happens when trying to set it up/log in to LastPass?
Most likely something was not updated since my payment.
Thank you
Hi@"johnny555"
You can contact support at any time by clicking on Contact Support at the bottom of any support article.
Look like this is a global f%^&k-up that no one is keen on fixing.
Had Families trial (I will know to stay away from your freebies now), now it's expired I can no longer upgrade -- payments never complete -- bank says LastPass never asks for CVC, hence failed transaction.
No wat to reach support either.
Thumbs up for customer service!
