Hello,
Could you try uninstalling the LastPass app, restarting your device then reinstalling the app to see if that resolves the issue?
Hi @arushton,
If you've already tried uninstalling the app, restarting your device, then reinstalling please report this bug to our technical team following the steps here:https://support.logmeininc.com/lastpass/help/how-do-i-report-a-bug-to-lastpass
I had the same problem, uninstalled etc. The battery use went right down, but about 2 days later it shot back up again. The android system reported that LastPass was using a lot of CPU. It seems to be a repeating problem, not a one-off. Is there a solution that means I won't have to repeat this cycle?
