Hi @tbrancazio
Welcome to the LastPass Community.
Please state what features are not working in LastPass for you.
Can you also state which device and LastPass app version you're working with?
all the free features are purposely going down one by one like "export" exporting to a CSV file, the option is there but it doesn't work, however if you use a paid version you can bet it will magically start working, it's just an underhanded way to keep control over your passwords behind a paywall for now for features other than storing your manually entered login data for use later by yourself and using it to help you log into sites are free and work, other features rarely work, so you have to use a paid version to make supposedly free features work, then eventually logging into each site will require paid version to work, later no free features will work, my advise manually store your login information for every site and service you ever used, make a secure backup file of it and a printed copy, keep it all in a safe or something or a bank safety deposit box and then if you want migrate it to a more dependable service that isn't so underhanded and grossly inco
Hello! @werner.marais
We want to apologize for the issue with your account, and all the browsers' features, this could be related to an outage at that time, right now you should be able to use all your free browsers features.
In case you have any issue please follow the steps above:
Could you please clean your internet browser (cookies and cache), log in to your LastPass account again, and try to replicate the issue?
In case you are still getting the same scenario, please remove the LastPass extension from your internet browser, and in case you have any other extension installed, please try to turn them off. Once that is done, clean your internet browser again, reinstall the LastPass extension, and try again.
Please let me know if you need additional help.
Greetings!
Verlaine | Customer Care
