Not sure what is going on here but I can't seem to call and I can't reach my vault.
Not sure if my issue is similar or not but I'm having issues getting my websites to "LAUNCH" from the webpage. I can log in okay but when I click "LAUNCH", nothing happens.
I am having the same issue. Why doesn't LastPass answer the question?
Hello LastPass,
Yournew Pop Up warning after loggingin will not go away. It pops up in the middleof my screen and there is no way to close or minimize it that I can find. It has rendered my LastPass access to my vault useless and impossible now. PLEASE remove this Phishing Kit alert asap; I am LOCKED OUT of many of my websites as a Irely on LastPass and now LP is the actualproblem! Tell me how to remove the Pop Up - I have seen it and I need to access my data.
Yes, I am having the same issue. It is extremely frustrating, you cant even log in to make a support request. They need to fix this, and quickly.
There is a support case from April 2023 that just says to clear cache, but that does not help. LP get you act together please.
I'm having the same issue and It's really frustrating. Do you already have an answer?
