Hi All,
I couldn't find a simple straightforward answer to this issue so forgive me is this is a duplicate of another entry.
Whenever I would try to sign into Ancestry.com, the username and password fields would be automatically filled in with a username and password I haven't used in years. It wasn't a big deal because I could just select the correct login from the LastPass drop-down and it would fill in correctly. However, I wanted to know where that username/password was coming from.After a few frustrating hour trying to figure out if the incorrect data was coming from Chrome, LastPass, or something else, I finally determined it was indeed coming from LastPass.
When I looked at the Ancestry.com entry in my vault, it was correct. So, where was the old data coming from? After some more frustrating searching, I discovered that LastPass keeps a history of your usernames and passwords. It can be displayed by clicking on the icon that looks like a clock with an arrow around it above the username or password fields. When I looked there, sure enough, there was the old username. I could not figure out how to delete the history at that point. So here is how I fixed the problem.
- Took note of my current username and password
- Completely deleted the entry for the site from my LastPass vault (clicked on the trash can icon at the bottom of the entry)
- Recreated the entry for the site (You can do that simply by going to the site and logging in with the correct username/password and LastPass will ask you if you want to add it.)
After that, the wrong username/password were no longer auto-filled into fields on the site. I have no idea why LastPass would use the username/password from the history instead of the current settings.
I hope this post helps someone else.
Thanks
