Hello @cpw020,
My name is Henry and I am happy to assist with your inquiry, and appreciate you contacting LastPass Support!
I am sorry about the issues you are having with your extension settings. It is possible that your browser is deleting the cookies and cache everytime you close all browser windows. If so, please either add lastpass.com as an exception or disable this feature.
If the issue persists, please follow our troubleshooting steps from this article.
Please let me know if this worked or if further assistance is required.
Thank you,
Henry | Customer Care
Hi Henry, I added [*.]lastpass.com as an cookies exception but the same issue persists, the lasttpass chrome extension defaults back to Automatically fill login information whenever I restart my computer, which is not the behaviour I want, specifically - because lastpass often fills in login information in the wrong field of input areas of software tools I use - this is disruptive and could cause data overwrite problems in my normal use. I will not be disabling all third party cookie protection; is any other solution available for LastPass product with its google chrome extension? Thank you in advance.
