Dear Support-Team,
I hope this message finds you well.
I am currently unable to use the “Request Help Logging in” form. Each time I attempt to submit the form by clicking “Save”, I receive the following error message:
Attempt to de-reference a null object
Class.RecordTypeIds: line 14, column 1
Class.CommunityCtrl.createCase: line 273, column 1
I have tested this across multiple browsers, in private/incognito mode, and on different devices, but the issue persists.
Could you kindly look into this and advise on a solution?
Thank you very much in advance for your support.
Best regards, ✌️
Kevin
