Thank you for the LastPass enhancement idea.
We are considering development of a LastPass app for Apple Vision devices, and all comments here will help add weight to the final decision.
Same request
Same request from me as well.
Same here!!!
I am also considering abandoning LP without support on Vision. It’s unbelievably painful to have to log in to websites again and again (since I don’t trust iCloud Keychain) - especially with the long, unique, randomized passwords I’ve built up over the years. Please please PLEASE support.
Another LastPass/Vision Pro user that needs either the iPad or Vision Pro app.
I am considering abandoning LastPass solely for the lack of Apple Vision Pro support. I’d really like to stay here. Huge up vote for this feature.
Hello Ash
Is the current version not compatible as it stands? In the App Store Connect, can you re-check the box to "Make this app available on Apple Vision Pro".
I don't think any of us are looking for a native spatial Apple Vision Pro app... a "compatible" app is good enough built on the iOS/iPadOS framework.
I am just tired of having to open my iphone copying a password and then pasting it in the Vision Pro.
Thanks for the consideration.
Workaround: if you use a laptop, you can connect it and copy passwords from the laptop to the AVP apps. It’s still very frustrating, but slight better than typing.
Please add support for vision pro
"Considering"? Apparently I am finding a different manager.
I came to find out how soon, this tells me not soon at all.
I will keep LP only if it shows up before I decide on an alternative and start migrating.
The crazy thing is LP is the only manager on Quest, which is why I wanted to keep it! Guess I'll sideload something in that case.
@Ash CannonJust flag the existing app as compatible. IOS apps are compatible by default, you just need to be up to date and not opt out.
The existing app being unavailable tells us LP CHOSE to opt out, or they were too outdated to be compatible.
Any update on LastPass working within Apple Vision Pro? I will be switching if this is not added soon.
It takes very little to enable compatibility with Apple Vision Pro. I could do it for you this weekend if you gave me access to your repo. Why wouldnt you do this? This is a huge problem for me! please please add support for the apple vision pro
I am a bit shocked that LastPass does not work on the AVP. It is important to recognize that the owners of an AVP (>$4k) are often the thought and tech leaders inside their companies/organizations. People ask us for our advice regarding software and hardware. By ignoring the AVP you will force us to move to other password managers. When we move so will those we advice or lead within our communities.
I’m thinking of setting an exodus date. If no support by June 1, I’ll switched to 1Password. Anyone want to join me?
Same. I will be dropping LastPass by June 1 if there is not an app in place to use on the AVP.
I’ve now dropped LastPass for Keeper, happy with that, others are probably good too. DashLane and BitWarden look promising too.
June 14, 2024. Still no support for AVP. Will be dropping LastPass.
LastPass or some other password vault would be an extremely valuable, if not necessary addition to the Apple Vision Pro experience. As such, it would create a great competitive advantage for LastPass to be first to market, even if the market is small, and would prevent otherwise happy clients from being forced to try alternatives because LastPass doesn't work on AVP and some other product does, and that means they have to switch platforms to retain synchronicity across all of their devices.
It’s crazy annoying not having this available on Vision Pro. Means having to type passwords in manually copying from phone, and it’s not easy to read thru the headset. Please add this asap!
It's really really a bad experience not having the password manager app available on such a productivity powerhouse! Please create an app, otherwise I need to switch to apple passwords
Adding to the request for AVP support. Really can’t be that difficult and if you can’t get it together then like many others I’ll need to move to alternative
Needs to happen or more customers likely to move
Yes Please.
Pleas
Please add
Yes, please I would like a version of LastPass for the Vision Pro thank you
I would use LastPass on the Vision Pro. Please create an app!
How does one transfer from LastPass passwords to Apple Passwords in bulk?
I switched to Apple Passwords and it’s been working great. You can export all your credentials from lastpass to passwords. It might not be for everyone and there are some features that aren’t as refined as last pass but it’s been fine for me. Just FYI
