Since yesterday embedded Tweets are being blocked in Microsoft Edge in all forums and are just showing as below.
I have no adblockers and disabled extensions one-by-one to find that LastPass was causing it. If I disable LastPass it works immediately, if I enable it, it stops working immediately. I suspect an update has caused this.
Anybody else getting the same?
